18 กุมภาพันธ์ 2561, 16:04 *
ผู้เขียน หัวข้อ: ลงบ้านเช่าไม่ได้  (อ่าน 1081 ครั้ง)
Golf Chainat
กระทู้: 17
« เมื่อ: 02 เมษายน 2559, 16:26 »
ผมใช้ cloud ibox 3 ลง FW ....open black hole 0.1
http://dl.dropboxusercontent.com/u/235792066/open%20black%20hole%200.1-ฉฉ%20cloud3%20by%20preelaw.rar
แล้วพยายาม ลงบ้านเช่า ที่ขอมาทดลองของ 9iptv เป็น CCcam
โดยใช้ DCC_E2 เข้าไปแก้ที่ CCam.cfg โดยเพิ่มโค้ดที่บรรทัดแรก
N: xxxx.xxxx.xx xxxx xxxxx xxxxx 0102030405060708091011121314
#   Config
SERVER LISTEN PORT : 32001
ALLOW WEBINFO: yes
WEBINFO USERNAME : root
WEBINFO PASSWORD : dreambox
WEBINFO LISTEN PORT : 16000
TELNETINFO LISTEN PORT : 16001
TELNETINFO USERNAME : root
TELNETINFO PASSWORD : dreambox
ALLOW TELNETINFO: yes
ZAP OSD TIME :0
OSD USERNAME :root
OSD PASSWORD :dreambox
OSD PORT :80
CARD READER : /dev/sci0
CARD READER : /dev/sci1
SERIAL READER : /dev/tts/0
SHOW TIMING : yes
SHOW EXTENEDED CLIENT INFO : yes
DEBUG : yes
NEWCAMD CONF : yes
DISABLE EMM : no
EXTRA EMM LEVEL : yes
EMM THREADS : 1
MINI OSD : yes
SOFTKEY FILE : /var/keys/SoftCam.Key
STATIC CW FILE : /var/keys/constant.cw
AUTOROLL FILE : /var/keys/AutoRoll.Key
CAID PRIO FILE : /var/etc/CCcam.prio
PROVIDERINFO FILE : /var/etc/CCcam.providers
CHANNELINFO FILE : /var/etc/CCcam.channelinfo
LOG WARNINGS : /tmp/warnings.txt
# Card Reader Slot Upper
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS : /dev/sci0
# Card Reader Slot Lower
CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS : /dev/sci1
# Serial Card Reader
SMARTCARD CLOCK FREQUENCY: /dev/tts/0 6000000
CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS : /dev/tts/0
แล้ว save รีสตาร์ทเครื่อง ก็ไม่ได้ครับ ใครก็ได้ช่วยที่
ปล.ผมกดไปstar CCcam แล้วก็ไม่ได้
ร้านค้าลงทะเบียน*
กระทู้: 1,242
« ตอบ #1 เมื่อ: 02 เมษายน 2559, 16:40 »
ถ้ามาเป็น C:  วางได้เลย
C: IP port user passwd
ถ้ามาเป้น N:   ตาที่ท่าน  post มาครับ
N: IP port user password 01 02 03 04 05 06 07 08 09 10 11 12 13 14
file  CCcam.cfg  อยู่ที่
/var/etc/CCcam.cfg
Avatar
กระทู้: 47
คุณยังมีที่ว่างสำหรับการแบ่งปันน้ำใจให้กัน เสมอ...
« ตอบ #2 เมื่อ: 02 เมษายน 2559, 16:41 »
ลองใส่แบบนี้ดูครับท่าน  Grin
C: Server Port Username Password
ใส่บ้านเสร็จ restart
Golf Chainat
กระทู้: 17
« ตอบ #3 เมื่อ: 02 เมษายน 2559, 16:57 »
/var/etc/CCcam.cfg
ผมได้มาเป็น  C:  ครับ ลองวางดูแล้ว ก็ยังไม่ได้ครับ
กระทู้: 942
« ตอบ #4 เมื่อ: 02 เมษายน 2559, 17:06 »
ที่ท่านปราโมทย์เขียน เลขชุด 00 .... 14 จะแบ่งวรรคเป็นชุดๆ
ส่วนที่ท่านทำตัวอย่างให้ดูจะเขียนติดกัน ไม่แน่ใจว่าจะเหมือนกันหรือไม่ครับ
เดาๆ เอาเพราะผมก็ไม่เคยใส่ N ไลน์ครับ
Golf Chainat
กระทู้: 17
« ตอบ #5 เมื่อ: 02 เมษายน 2559, 17:06 »
ลองทำแล้วยังไม่ได้ครับ  Huh?
Golf Chainat
กระทู้: 17
« ตอบ #6 เมื่อ: 02 เมษายน 2559, 17:24 »
มันขึ้นแบบนี้
Golf Chainat
กระทู้: 17
« ตอบ #7 เมื่อ: 02 เมษายน 2559, 17:28 »
ก็ยังไม่ได้ครับ แปลกใจมาก
Golf Chainat
กระทู้: 17
« ตอบ #8 เมื่อ: 02 เมษายน 2559, 17:58 »
ได้แล้วครับ  ขอบคุณทุกท่านมาก  ลงเปลี่ยน ipดูได้เลย
